spindle out issue 7i76 SOLVED
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Dec 2019 14:13 - 10 Dec 2019 12:54 #152360 by bevins
spindle out issue 7i76 SOLVED was created by bevins
I have 78i76 with cm on pint TB4 and 5V pin3. I have pin2 going to inverter.
I see no voltage on pin 2 when I do m3 S16000. hal config show spindle enabled and 16000 for rpm.
Below are my hal and ini.
HAL:
Warning: Spoiler!
INI:
Warning: Spoiler!
Last edit: 10 Dec 2019 12:54 by bevins.
09 Dec 2019 14:50 #152363 by PCW
Replied by PCW on topic spindle out issue 7i76
Your hal file is missing the net connections from the signals:
spindle-vel-cmd-rpm
and
spindle-enable
to the appropriate hardware pins
  • bevins
  • Platinum Member
  • Platinum Member
09 Dec 2019 17:02 #152376 by bevins
Replied by bevins on topic spindle out issue 7i76
spindle-vel-cmd-rpm
and
spindle-enable
I connected spindle-vel-cmd-rpm to hm2_7i92.0.7i76.0.0.spinout
and
spindle -enable to hm2_7i92.0.7i76.0.0.spinena
and no matter what speed I send it it sends out 4.8volts spinout
  • bevins
  • Platinum Member
  • Platinum Member
09 Dec 2019 17:15 #152381 by bevins
Do I need to set spinout-minlim and spinout-maxlim?
I am having issue and I dont understand the spindle.
Is their a 7i76 config somewhere I can look at? I thought stepconf set it all up.
09 Dec 2019 17:40 - 09 Dec 2019 18:34 #152386 by PCW
pncconf normally sets this up, I suspect you may have left out some spindle setting
that pncconf uses to enable installing the spindle connections
And yes, the reason you have a constant ~5V output is likely that the scale is wrong
Normally you would set minlim to 0 and maxlim and scale to the spindle speed at full voltage
EDIT: I just tried this with pncconf and it does setup the nets and scaling.
Pretty sure you need to fill out the "7I76-Analog Output TB4" tab before
pncconf will create the connections and scaling setp's
Heres what pncconf creates:
setp hm2_5i25.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-output => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable => hm2_5i25.0.7i76.0.0.spinena
net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir
Last edit: 09 Dec 2019 18:34 by PCW.
  • bevins
  • Platinum Member
  • Platinum Member
09 Dec 2019 22:36 #152400 by bevins
I fixed it by hand. I will look into setting that with pncconf. I know I missed that section I guess.
Anyway, its working, thanks.
Time to create page: 1.338 seconds
