Mill with auxilarry spindle
6 years 7 months ago #159182 by bobhare
Replied by bobhare on topic Mill with auxilarry spindle
Thanks again.
I modified the hal file in line with the post i mentioned earlier and Linuxcnc now opens. With the settings i had for position control i get the error, " joint 3 following error. I've played around with the max velocity and acceleration as well as ferror and min ferror without success. I've tried using m3s1000 to no avail.
File Name: MLV1_2020-03-04.hal
File Size:3.73 KB
File Name: MLV1_2020-03-04.ini
File Size:2.16 KB
I've also tried changing Axis 3 in the ini file that suggested in the above post again without success. The change was to delete the Axis 3 element and replace it with:-
[AXIS_3]
STEPGEN_MAXACCEL = 1125.0
SCALE = 100
I've reduced these two parameters; no joy.
I'm sailing round in a sea of uncertainty and perhaps the problem still lies in the hal file!
6 years 7 months ago - 6 years 7 months ago #159187 by PCW
Replied by PCW on topic Mill with auxilarry spindle
To combine both position mode (for A Axis use) and velocity mode (for spindle use)
is fairly complicated. I think it can be done with one stepgen in velocity mode
but requires a PID component and a bunch of signal re-routing depending on mode
plus dealing with the following error issue.
With software stepping, I suspect the simplest way would be to
have two stepgens (adding one to your existing configuration) ,
one setup in normal position mode for the A axis and one setup in velocity
mode for spindle use.
Then whatever signal you use for changing modes routes either the A axis
step/dir pins or the spindle step/dir pins to the physical parallel port pins
using either a mux_generic or a couple of lut5 components in hal to select which
stepgens step/dir pins get routed to the hal parallel port pins that drive the A axis/spindle.
If you dont need A axis gcode at all but just a variable speed, its much simpler .
You would just delete all the A Axis setup in your ini file and connections in you hal
file and just set the spindle velocity in the gcode.
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago #159277 by andypugh
PCW wrote: To combine both position mode (for A Axis use) and velocity mode (for spindle use)
but requires a PID component and a bunch of signal re-routing depending on mode.
Here is a picture:
wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient
Note that is showing the config for a VFD, but the principle is very similar for a velocity-mode stepgen.
Time to create page: 0.133 seconds
