No movment from stepper motors
6 years 5 months ago #167544 by Nate
Good afternoon i am new to the cnc world and with all this covid time i have decided to dig into a diy cnc plasma i have installed linuxcnc mint 19 the easy way provided my tommylight. i have a mesa 7i96 board with china version of the tb6600 motor driver. here is a copy of my ini and hal file. I can get the computer to turn on the spindle output that that i am wanting to use to run the plasma but i have no movement from the stepper
File Name: Nathan_Plasma.ini
File Size:4.36 KB
File Name: Nathan_Plasma.hal
File Size:9.96 KB
motors any help is greatly appreciated.
6 years 5 months ago #167550 by tommylight
Try turning the motors by hand when powered on, they should be stuck and not move easily.
If they can still be moved, the enable is not set or wired properly. For testing you can disconnect the enable wires.
6 years 5 months ago #167552 by Nate
Replied by Nate on topic No movment from stepper motors
there is a buzzing sound coming from the motors and when powered they do not move easy at all
6 years 5 months ago #167554 by tommylight
6 years 5 months ago #167562 by Nate
Here is what I have let me know if you need more
6 years 5 months ago #167572 by PCW
Replied by PCW on topic No movment from stepper motors
Since these have a TB6600 and added optoisolation you might try 10000
for steplen. If this does not work you might try single ended drive:
7I96 +5 to step drive +pul and +dir
7I96 -dir to step drive -dir
7I96 -step to step drive -pul
Time to create page: 0.186 seconds
