confused about velocity settings in the INI
6 years 4 months ago - 6 years 4 months ago #171382 by Aciera
I have a bar loader configured as a U axis in a mill configuration using stepper motors. This u axis, unlike all other axis, is a direct drive rack and pinion. Because this feeder has a travel length of 4 meters I want to increase the G0 rapid velocity by about a factor of 10 without affecting the settings of the other axis.
Warning: Spoiler!
Now I got myself confused about all the different velocities and acceleration settings in the INI file.
So we have this in the DISPLAY section:
this in the TRAJ section
this in the AXIS section:
this in the JOINT section:
and this in the joint section that is actually for the hostmot2 stepgen
So my understanding is that in JOINT mode (so also for the homing process since there is no axis before the joint is homed) the settings in the JOINT section are relevant. After homing it is the AXIS section.
So then in the DISPLAY section we set the min/max values for the jog slider in the GUI and the TRAJ setting are for the motion planner.
So in order to increase the G0 velocity for the U-Axis only I should just be able to increase the settings in the U-AXIS section.
I tried that but it does not seem to make a difference. The U-AXIS still moves at about 25mm/s.
Because the machine is already in use I can't spend to much time fiddling with it. So I would like to have a somewhat clear understanding of what my approach should be.
So should I increase the TRAJ velocity and the JOINT and the AXIS for U? Should the settings in the JOINT and AXIS sections always be the same?
Last edit: 6 years 4 months ago by Aciera.
6 years 4 months ago #171384 by bbsr_5a
it will be a error if the AXIS and Joint settings are not the same
for UW the Values are also in Machine units
and ofcause in per second
6 years 4 months ago #171419 by tommylight
Display section = limits the slider velocity in the GUI
Traj section limits overall machine velocities
Per axis/joint section limit that axis/joint
I always set the display and traj section about 25 % more than any of the axis, so when i jog X and Y together it can reach both axis/joint speeds, without clipping them. When two axis move together, the distance travelled is longer than that of each axis.
So to increase the U axis speed, the display and traj have to also be raised.
6 years 4 months ago #171435 by Mike_Eitel
In theorie you should set it to the square root of three. Ca 1.7
6 years 4 months ago #171448 by bbsr_5a
refering to his other post he managed it and got a running machine
6 years 4 months ago - 6 years 4 months ago #171459 by Aciera
So to be able to run the u-axis at 12000mm/min I would set
TRAJ and DISPLAY settings to 12000 x 1.25 = 16000 = 266
U-AXIS and JOINT to 12000 = 200
I'll try that.
@bbsr_5a: Not sure what you are referring to.
Time to create page: 0.217 seconds
