Machine Stutter / Notching Phenomenon
5 years 10 months ago #190910
Replied by tommylight on topic Machine Stutter / Notching Phenomenon
Run some simple gcode to move the machine from one side to the other.
If that is happening while jogging it might be an keyboard/bios.
5 years 10 months ago #190913
by AlexDoran
Replied by AlexDoran on topic Machine Stutter / Notching Phenomenon
It does it when running gcode and also when jogging manually
Ive literally read every lost steps thread on LinuxCNC i think haha.
I do have a Touchscreen Monitor on the PC but i had the problem before i added this.
I think its so bizarre it works perfectly fine on stepconf but not once i actually load into LinuxCNC.
I have alot of Spare PC's here i could test but none have a Parallel Port lol. Ill try and get another video tomorrow.
The only setting i could really see from the GUI that i thought maybe could affect performance, was i think the refresh rate of the gui?? Maybe i should try changing this from 0.1 or whatever its set to, to 1 - 2.
5 years 10 months ago #190958
by AlexDoran
Is there a way to test all 3 Axis simultaneously through stepconf?
5 years 10 months ago #190961
Or you can use the "calibration" from the "machine" menu in LinuxCNC.
Nope, but you can save it and test and open and edit again in stepconf.AlexDoran wrote: Is there a way to test all 3 Axis simultaneously through stepconf?
5 years 10 months ago #190965
by AlexDoran
AARRGGG I finally fixed it.
Whatever this line, and wherever it came from, I don't know.
Setp parport.0.pin-xx-out-reset-1
As soon as that was gone my troubles are fixed, I ran a new config fresh from Stepconf and this was the only difference I could find.
Machine is running great now and buttery smooth again. Just a shame I wasted nearly a whole week on this.
Thanks again all for your help it's greatly appreciated.
5 years 10 months ago #190970
by Clive S
Glad you fixed it. But I think that line was not in the hal file you posted.
Now you can get on with your life
Replied by Clive S on topic Machine Stutter / Notching Phenomenon
Time to create page: 0.081 seconds
