New build
5 years 9 months ago #194088 by tommylight
Replied by tommylight on topic New build
They do not show on the IO tabs, they show on the first 7i77 page where the axis are set up.
The only latency number that needs entering or changing is the Base_period when using parallel port, Servo_period should not be changed.
5 years 9 months ago #194176 by jfrahm3310
Replied by jfrahm3310 on topic New build
So I'm trying to run the test and tune and got this error. I have all the encoders reading. I included a shot of the error and also some io pages , I tried to launch the test panel on these pages and nothing happeneds.
5 years 9 months ago #194179 by tommylight
Do not use pncconf for tuning, if i remember correctly it is for open loop testing, but i never used it.
Use this:
5 years 9 months ago #195118 by jfrahm3310
What does the max output in servo calibration page do?
5 years 9 months ago #195122 by tommylight
Max output is exactly that, the maximum the controller will output to the servo drive, it is used in cases where limiting the output to a certain value is needed.
It is also dependent on the output scale and output min and max values.
I would not touch that.
In the how to it is clearly explained what to set and tune and why and how, the rest should not be changed.
Time to create page: 0.170 seconds
