Encoder for axis tacho feed back
5 years 7 months ago #204271 by aleksamc
Have you read my post in the past?
What about polarity of your simulated output to servodrive?
I wrote you that Feadback from tacho always Positive.
The following user(s) said Thank You: johnmc1
5 years 5 months ago #208205 by johnmc1
PCW replied
"Maybe the Fanuc Tachometer simulator is unipolar?
You might try running the velocity through the abs component
before feeding it to the analog output hardware so the velocity signal
is always positive"
I have not been able to run (or understand) the abs component , to get, only positive tacho feedback, and as I do not know where to start.
Any advice or direction will be most appreciated.
At present all I have managed is to add ,
loadrt abs count=1
addf abs.0
net x-pos-fb <= hm2_5i24.0.encoder.00.position
net x-vel-fb <= hm2_5i24.0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_5i24.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i24.0.encoder.00.rawcounts
net x-enable hm2_5i24.0.7i83.0.4.analogena0
net x-vel-fb hm2_5i24.0.7i83.0.4.analogout0
setp hm2_5i24.0.7i83.0.4.analogout0-maxlim 277.7777
setp hm2_5i24.0.7i83.0.4.analogout0-minlim -277.7777
setp hm2_5i24.0.7i83.0.4.analogout0-scalemax 277.7777
cheers john
5 years 5 months ago #208266 by PCW
loadrt abs count=1
addf abs.0 servo thread
net x-vel-fb => abs.0.in
net x-vel-fb-abs <= abs.0.out
net x-enable => hm2_5i24.0.7i83.0.4.analogena0
net x-vel-fb-abs => hm2_5i24.0.7i83.0.4.analogout0
5 years 5 months ago #208298 by johnmc1
Many thanks PCW for your reply.
The Fanuc Tachometer simulator is not unipolar, when using the abs component.
A negative, axis motion command, will result in instant motor runaway.
A positive , axis motion command , will result with correct movement.
I intend to try another servo drive ,motor combination that is known to be correct .
cheers john
Time to create page: 0.059 seconds
