Open Loop Spindle control with DYN4
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
5 years 7 months ago #204332 by BeagleBrainz
Replied by BeagleBrainz on topic Open Loop Spindle control with DYN4
Michael wrote: Seems you got it figured out then
No.
I still need a bit of advice in going from a closed loop to open loop config.
5 years 6 months ago #204566 by andypugh
BeagleBrainz wrote: I still need a bit of advice in going from a closed loop to open loop config.
Set P, I, D FF1 and FF2 to zero.
Then adjust FF0 to get the correct speed.
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
5 years 6 months ago #204588 by BeagleBrainz
Ok so I still need PID that's great to know.
Had it running last night on the test bench, feeding (using correct hal notation)
spindle.0.speed-out straight to hm2_7i92.0.7i83.1.5.analogout5 and was able to get movement, the 7i83 was supplying a calculated voltage that was correct.
#******************* # SPINDLE S (open loop) #******************* setp pid.s.Pgain 0 setp pid.s.Igain 0 setp pid.s.Dgain 0 setp pid.s.bias 0 setp pid.s.FF0 "adjust to suit" setp pid.s.FF1 0 setp pid.s.FF2 0 setp pid.s.deadband 0 setp pid.s.maxoutput 4000 setp pid.s.error-previous-target true #net spindle-index-enable <=> pid.s.index-enable hm2_7i92.0.encoder.00.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command #net spindle-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output setp hm2_7i92.0.7i83.1.5.analogout5-scalemax 4000 setp hm2_7i92.0.7i83.1.5.analogout5-minlim -4000 setp hm2_7i92.0.7i83.1.5.analogout5-maxlim 4000 net spindle-output => hm2_7i92.0.7i83.1.5.analogout5 net spindle-vel-cmd-rpm <= spindle.0.speed-out
Does the above look right or am I wayyyyy off ? (assuming I have loaded pid.s)
Eventually the encoder output from the servo driver will get connected up, just need to get hold of a small amount of 3 pair shielded twisted pair.
5 years 6 months ago #204615 by johnmc1
Have you enabled analog5 elswhere.
  • BeagleBrainz
  • Topic Author
  • New Member
  • New Member
5 years 6 months ago #204629 by BeagleBrainz
Yup, otherwise no magic smoke through tiny copper pipes ;)
5 years 6 months ago #204634 by andypugh
BeagleBrainz wrote: Ok so I still need PID that's great to know..
No, you don't need the PID, but if you want to leave it in place and disable it, that is possible by making it an FF0 passthrough.
spindle.0.speed-out => hm2_7i92.0.7i83.1.5.analogout5 is the simplest open-loop arrangement, but needs more HAL changes from where you were.
Time to create page: 0.148 seconds
