xhc-whb04b-6 OPTIONS [-f -s] dont work
4 years 8 months ago #234689 by zz912
I want use OPTION:
-s Lead + jogwheel changes the spindle override speed. Each tick will increase/decrease the spindle override. -f MPG + jogwheel changes the feed override. Each tick will increment/decrement the feed override.
But in real this OPTION do nothing. I don't know if this is a bug or I can't use the remote control I tried to press different combinations of buttons on the remote control, but turning the jogwheel does not affect any HAL pin related to SPINDLE or FEED.
I dont understand have to change feed.  What mean "MPG + jogwheel" ?
I understand it for spindle"Lead + jogwheel" =>
it is so? But this make no change HAL pin.
4 years 8 months ago - 4 years 8 months ago #234711 by alkabal
Hi
For sure that work if you use the exemple hal file provided
The pendant support 4 mode and you can show that on the lcd.
Deffaut mode display MPG so you can directly use the jog wheel for see federate changing on the axis GUI slider
If you push continuous or step button you can see the Lcd displaying correspondant information this 2 mode the machine
Lead position is used for spindle feed override (check axis GUI slider)
After going back from lead you come again to MPG and corresponding federate override.
The only know options that does not work is the B (for remove big step usage)
Best regards
Last edit: 4 years 8 months ago by alkabal.
4 years 8 months ago #234719 by zz912
what version of Lcnc are you using?
4 years 8 months ago - 4 years 8 months ago #234741 by alkabal
2.8.2 (run in place) update done something like near 23 Jun 2021
I have the 6 axis unit, i don't know if the 4 unit work the same for MPG mode ???
HAL related signal for spindle :
halui.spindle.0.override.scale
halui.spindle.0.override.value
halui.spindle.0.override.increase
halui.spindle.0.override.decrease
HAL related feed : halui.feed-override.value    halui.feed-override.increase halui.feed-override.decrease
4 years 8 months ago #234755 by zz912
I have 2.8.2 too
whb.halui.feed-override.value
and
whb.halui.spindle-override.value
have DIR IN, so information flow to remote control.
I would like to ask you two things:
1) start a Halshow and see if these two HAL pins change when you change the feed with the wheel
if not look at Halscope.
2) do not turn off LCNC. Open the terminal and send me a pin list.
4 years 8 months ago #234772 by alkabal
Warning: Spoiler!
Time to create page: 0.441 seconds
