Advantage of closing the position loop in LinuxCNC
2 years 6 months ago #299042 by Ehsan_R
Yes, I can see the encoder data in the show hal congratulations menu
Can you explain in detail how to do this?
2 years 6 months ago #299051 by tommylight
2 years 4 months ago #302898 by Ehsan_R
Personally the main thing that makes my life much easier is the ability to disable motors and move the machine by hand and still have the position correct, enable motors and continue working! :)
Please explain how you do this?
2 years 4 months ago #302914 by tommylight
-encoder feedback must be wired and used by LinuxCNC
-enable output must be wired to drive enable inputs
The following user(s) said Thank You: Ehsan_R
2 years 4 months ago - 2 years 4 months ago #303094 by Ehsan_R
And how is the hal configuration?
net     joint.0.motor-pos-fb    Encoder.0.position ?
Last edit: 2 years 4 months ago by Ehsan_R.
Time to create page: 0.182 seconds
