tool radius compensation
3 years 8 months ago - 3 years 8 months ago #265513 by MaHa
Replied by MaHa on topic tool radius compensation
Before i tried to explain, linuxcnc needs (too)much space for lead-in when use G41 g42. I tried your code, and any cutter larger than 10mm will generate this error. Easy to test yourself. Try entry in tooltable Dia 10.001 vs. 10.00
Last edit: 3 years 8 months ago by MaHa.
3 years 8 months ago #265563 by Routercnc
Replied by Routercnc on topic tool radius compensation
I changed the diameter of the tool to 10 but it continues to make the hole larger than the measurement of 20mm " 21.68mm... I increased the diameter of the tool to 11mm it did not accept it linuxcnc gave an error
3 years 8 months ago #265570 by MaHa
If your tool has exactly 12mm diameter, you can try toolpath toolcenterpoint and it must result a 20mm diameter
G17 G21 G40 G90 G94 T1 M6 G54 S5000 M3 F800 G0 Z30 X0 Y0 Z10 G1 Z0 G1 X4 G2 X4 Y0 I-4 J0 Z-5 P5 G3 X4 Y0 I-4 J0 G1 X0 Y0 G0Z30 M30
3 years 8 months ago #265572 by Routercnc
I made the holes that way... but with the wear of the tool I'll always have to correct it in the program so I wanted to try using tool radius compensation... I'm going to abandon G41, it doesn't work using it here
3 years 8 months ago - 3 years 8 months ago #265574 by MaHa
This way you can use tooltable and compensate wear, without G41/G42
#5410 is diameter of loaded tool.
Just remembered G64. If there is not something like 'G64 P.005' , it may give unwanted results
G17 G21 G40 G90 G94 T1 M6 G54 S5000 M3 F800 G0 Z30 X0 Y0 Z10 G1 Z0 G1 X[10 - [#5410 / 2]] G2 X[10 - [#5410 / 2]] Y0 I-[10 - [#5410 / 2]] J0 Z-5 P5 G3 X[10 - [#5410 / 2]] Y0 I-[10 - [#5410 / 2]] J0 G1 X0 Y0 G0Z30 M30
3 years 8 months ago #265587 by Routercnc
I tested this program, but the diameter was huge..
I changed the cutter from 12mm to 10mm, the tool diameter compensation worked..
Time to create page: 0.213 seconds
