- Thank you received: 14
Can't wire DM556T to parallel port breakout board
- Routerworks
- Topic Author
3 years 4 months ago #273019
by Routerworks
Can't wire DM556T to parallel port breakout board was created by Routerworks
I have attached some pictures of the Sainsmart parallel port breakout board and the DM556T driver from stepperonline. The data sheet for the driver says the inputs are opto isolated so I tried wiring it both ways (sinking and sourcing from the breakout board) motor doesn't move. attached the motor to a different driver the Leadshine DM860e and it rotates fine. This one has me stumped. I know the sainsmart is not a high quality board but I wanted to get things working before I put more money into it. Built a 4' x 4' cnc router. Using nema 23 (425oz) stepper motors.Could be the breakout board is not good but I looked at voltages and resistance pin for pin with the axis that works at is seems pretty close. Not sure what I am missing short of buying a better breakout board.Any help would be appreciated especially If I am not seeing something in the wiring scheme of things.
- Thank you received: 5334
3 years 4 months ago #273026
Replied by PCW on topic Can't wire DM556T to parallel port breakout board
Looks like the common + pins (white wire) are unconnected.
These need to be connected to +5V
3 years 4 months ago #273029
Replied by tommylight on topic Can't wire DM556T to parallel port breakout board
Also disconnect the enable from drive untill you get things working.
That is usually a disable on new-ish drives, so it's counter intuitive and causes headaches.
- Routerworks
- Topic Author
3 years 4 months ago #273042
by Routerworks
Replied by Routerworks on topic Can't wire DM556T to parallel port breakout board
You are exactly correct. I did get it working in one direction after tripping upon a youtube site saying DM556 (no T whatever that means) requires 0 vdc on enable.
After attaching 5 vdc as you suggested to the looped plus terminal the skies parted and it all began to work fine in both directions.
I don't quite understand why it was working in one direction without the voltage applied to the loop but that's a discussion for another day. I wasted enough time on this. you would think it might be in bold letter on the data sheet for the driver.
Regardless,
Many thanks.
Regardless,
Many thanks.
Time to create page: 0.054 seconds
