Mesa 7i96s Inputs won't work
2 years 6 months ago #298433 by koernchen
we installed LinuxCNC with a Mesa 7i96s. The Servomotors and  the outputs are working fine but none of our imputs are working.
we wired inCom to GND and In00 to +5V but neither the onboard LED or the Halshow shows anything.
Is there anything to try or to do? Is the board dead?
thanks
- Tobias
2 years 6 months ago #298438 by PCW
Replied by PCW on topic Mesa 7i96s Inputs won't work
Are you sure you have input common (P3 pin 12) connected correctly?
An LED/Input might not work if it had been mechanically damaged, thats
the only other thing I can think of.
2 years 6 months ago #298444 by koernchen
We measured the voltage between common and in00, it was close to 5V.
Is there any Option to confirm a mechanical damage?
2 years 6 months ago #298445 by PCW
Try another input
2 years 6 months ago #298481 by koernchen
Sadly I tried every input
2 years 6 months ago #298482 by PCW
Sounds like your input common connection is not connected
Time to create page: 0.218 seconds
