- Thank you received: 3
Wonderful hint, thank you.Try
sudo apt install r8168-dkms
You need the linux headers for your RT kernel installed
More info here
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Thank you very much PCW, you've been very helpful with this machine in private emails in the past as well.To get an idea of where you are is to run the command:
halcmd show param *.tmax
When LinuxCNC is running.
These times will be in CPU clocks on X86 CPUs
Also the ping times (pinging the Mesa card) will help
Sorry about that. Very odd it did not work. Its been a while since i tried it.Small note for anyone in the future, the dkms driver actually made my latency worse and lcnc unusable. I guess I should always test.
following error and a read error almost instantly from hostmot2.
