Extremely confused - Nonworking limit switches
1 year 1 month ago #335603 by ffffrf
*in both cases the switch is clearly working in pncconf
- I am totally stumped - i guess it could be a bad version of linuxcnc? I havent had any issues with it since setting it up for the first time, only now with this second mesa board. You recommend I update linuxcnc? Will try to do so tomorrow morning
1 year 1 month ago #335634 by PCW
As a data point, your config1 and config2 (MODLATHE and taig_new)
works as expected with LinuxCNC 2.9 and Master with a 7I96S
and I can alternate running MODLATHE and taig_new without
issue.
That is, the inm inputs work properly on both.
1 year 1 month ago - 1 year 1 month ago #335635 by ffffrf
Hmm.... I am on 2.9.2 which i believe is stable right? I am debating just doing a clean reinstall of everything at this point?
Are you specifically using like 2.9.0? Should I try that?
Last edit: 1 year 1 month ago by ffffrf.
1 year 1 month ago #335636 by ffffrf
ISSUE RESOLVED
Problem: unknown, could not locate source of the error
Solution: Updated to 2.9.4
lesson learned, dont forget to try the simple stuff :)
1 year 1 month ago #335637 by PCW
The hal file text showed 2.9 master, not a standard release.
Time to create page: 0.171 seconds
