mesambccc init feature question
- jtrantow
- Thank you received: 22
25 Feb 2026 21:48 #343500
by jtrantow
mesambccc init feature question was created by jtrantow
I have my 7i96 working with a CommanderSK VFD over RS485 with hm2_modbus. (See attached)I write two registers using the init section but I haven't figured out the syntax to read registers in this section. Could anyone provide an example of reading registers during init? I'd like to only read the rated rpm, amps, etc once and I need the values in hal.I would also appreciate an example showing how to set the HAL_FLOAT scale factors. (in the .mbccs) I am currently usingĀ
setp hm2_modbus.0.vfd.ref-coarse-00.scale 10.0
It seems like this belongs within the .mbccs definition.Please Log in or Create an account to join the conversation.
- Thank you received: 7280
25 Feb 2026 22:49 #343501
Replied by tommylight on topic mesambccc init feature question
Moved to "driver boards"
Time to create page: 0.092 seconds
