largest NC file
4 months 1 week ago #347179 by lgrfbs
largest NC file was created by lgrfbs
What was the size of your largest NC file?
A few days ago, I made a mistake by putting a "-" in front of a value that was supposed to be positive in FreeCAD's CAM workbench, which resulted in an NC file that was 20,590 kB or 688,627 lines long.
The file was never run, since I caught the error.
So I was wondering—how large have the NC files you've generated been?
4 months 1 week ago #347186 by rodw
Replied by rodw on topic largest NC file
from what I understand, that would likely run but the screen preview might have a big spasm!
4 months 1 week ago #347191 by lgrfbs
Replied by lgrfbs on topic largest NC file
Sorry for the rambling post.Since I ended up with a huge NC file when I was CAM-processing a project, I got curious—how big do NC files have to be to be considered “big” for you guys?
4 months 1 week ago #347192 by tommylight
Replied by tommylight on topic largest NC file
I am pretty sure i have used bigger than 20MB files, probably 55MB, but a bit fuzzy on that.
dmap2gcode that i use for engraving/scratching and laser, makes huge files.
4 months 1 week ago #347198 by MaHa
Replied by MaHa on topic largest NC file
I used the 3D job i was working on today, set xy and z-steps to very low values, in the cam. The resulting file has 1601179 lines / 38.1 MB  It took about 2 minutes to load. Then i doubled the file to 3202358 lines. 16 GB Ram and 1 GB swapfile was insufficient,  Linuxcnc crashed. It seems, if there is enough memory, very large files can be loaded.
4 months 1 week ago #347225 by MikkelRS
Replied by MikkelRS on topic largest NC file
At work I use a 5axis large format machine, ive had over 100mb files before cutting for ~25 hours.
It has a tool changer but rarely used since it gets full of crud- crappy gantry design with very little dust extraction.
Much fun!
Time to create page: 0.075 seconds
