Homing switch setup in hal
3 months 3 weeks ago #347601 by RLA
Hi...I have a mechanical home switch wired as seen from others but does not seem to be functioning...I am not sure I have hal right for x home switch...I have pin # 2  from mesa 7196s going to nc on switch...Input common to 24v ground on  power supply  and switch common to 24v power supply v+...I am not very good with electric so any help would be greatly appreciated..
Thanks,
Rick
3 months 3 weeks ago #347605 by PCW
Replied by PCW on topic Homing switch setup in hal
TB3 pin Pin 2 would be GPIO 01 (but actually you should be using INM pins, not GPIO)
Pncconf setup would be something like:
(invert it using NC switches)
You should also use halshow to verify home switch operation before attemting to home
3 months 3 weeks ago #347606 by RLA
Replied by RLA on topic Homing switch setup in hal
Hi...I used pin that is labeled iN2....and put in Hal as GPIO 002....when I tried to test in Halshow nothing happened....i checked wiring seems ok....I did not know if i am missing something in Hal...I only put  info  in the x axis section...
# ---# external input signals...under this part it is blank..
setup home / limit switch signals---
net x-home-sw <=  hm2_7i96s.0.gpio.002.in_not
net x-home-sw <= joint.0.home-sw-in
Thanks for reply!!
3 months 3 weeks ago #347607 by PCW
Does the yellow LED near IN2 operate as expected?
3 months 3 weeks ago #347608 by RLA
I forgot about that.....no
3 months 3 weeks ago #347609 by RLA
if I go to V- instead of power supply ground IN2 lights...is that ok? or does it indicate a different problem?
Time to create page: 0.279 seconds
