Homing switch setup in hal
3 months 3 weeks ago #347613 by RLA
Replied by RLA on topic Homing switch setup in hal
So all is working now....thanks again for your help...I am not sure what INM pins are...would I need another board?
Thanks again!,
Rick
3 months 3 weeks ago #347617 by PCW
Replied by PCW on topic Homing switch setup in hal
If you use a recent pncconf it will use the INM pins rather than the GPIO pins
The INM pins have the advantage that they are debounced. Standard 7I96S
firmware has INM on all isolated I/O pins (the GPIO pins work but the built-in
debounce is often an advantage)
The following user(s) said Thank You: RLA
3 months 3 weeks ago #347626 by RLA
Got it..Thanks...Have not been using the pncconf ...I am using 9 axis and I was afraid it would overwrite ...
Thanks again!!
3 months 3 weeks ago #347643 by PCW
You can always  use pncconf/MesaCT to create a sample configuration
to copy/paste from, if you don't want to possibly corrupt your hand edited file.
Time to create page: 0.204 seconds
