- Thank you received: 2181
I did not see it first. Now I found the option, thank you!You must select 'up/down mode' in the pintype combo box to have pncconf use output type 2. Did you do that?
Yes, I mean X axis, which I assigned to PWM 0.You say axis 0 do you mean X axis ? what happens with the other axis?
Yes I mistyped here.You typed 'SVST_6_6' is that a typo on your part? The name is 'SVST6_6'
I just created another new config with SVST6_6, saved it, shut down pncconf, started it again and TPEN4_5 shows too.I can't repeat this error. the config used the proper name. Something else must have gone on.
