MESA 7i96s + 7i77 how to get file .bit for flash
3 years 2 months ago #279272 by abdulasis12
Hi
I have 2 board  7i96s and 7i77
I need connect 7i77 via P1 port.
I read found
forum.linuxcnc.org/39-pncconf/37890-mesa...work-together#151351
I go to D/L from mesanet I got file but inside folder 7i96s.zip\7i96s\configs\hostmot2 is  2type  = .bin and .pin  not have .bit file
I go try to D/L of 7i92 and 7i76E inside folder have .bit image missing /media/kunena/emoticons/laughing.png​​​​​​​
how to  flash for 7i96s ?
3 years 2 months ago #279273 by PCW
7i96s_7i77d.bin is the proper firmware file for a 7I96S + 7I77
The following user(s) said Thank You: abdulasis12
3 years 2 months ago #279274 by abdulasis12
Thank you for reply MR.PCW
After I flash this is result
asis@192:~$ sudo mesaflash --device 7i96s --addr 10.10.10.10 --readhmid Configuration Name: HOSTMOT2 General configuration information:   BoardName : MESA7I96   FPGA Size: 20 KGates   FPGA Pins: 256   Number of IO Ports: 3   Width of one I/O port: 17   Clock Low frequency: 100.0000 MHz   Clock High frequency: 200.0000 MHz   IDROM Type: 3   Instance Stride 0: 4   Instance Stride 1: 64   Register Stride 0: 256   Register Stride 1: 256 Modules in configuration:   Module: DPLL   There are 1 of DPLL in configuration   Version: 0   Registers: 7   BaseAddress: 7000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: WatchDog   There are 1 of WatchDog in configuration   Version: 0   Registers: 3   BaseAddress: 0C00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: IOPort   There are 3 of IOPort in configuration   Version: 0   Registers: 5   BaseAddress: 1000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: OutM   There are 1 of OutM in configuration   Version: 0   Registers: 1   BaseAddress: B000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: PWM   There are 1 of PWM in configuration   Version: 0   Registers: 5   BaseAddress: 4100   ClockFrequency: 200.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: StepGen   There are 5 of StepGen in configuration   Version: 2   Registers: 10   BaseAddress: 2000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: MuxedQCount   There are 8 of MuxedQCount in configuration   Version: 4   Registers: 5   BaseAddress: 3600   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: MuxedQCountSel   There are 1 of MuxedQCountSel in configuration   Version: 0   Registers: 0   BaseAddress: 0000   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: SSerial   There are 1 of SSerial in configuration   Version: 0   Registers: 6   BaseAddress: 5B00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 64 bytes   Module: SSR   There are 1 of SSR in configuration   Version: 0   Registers: 2   BaseAddress: 7D00   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: InM   There are 1 of InM in configuration   Version: 0   Registers: 5   BaseAddress: 8500   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes   Module: LED   There are 1 of LED in configuration   Version: 0   Registers: 1   BaseAddress: 0200   ClockFrequency: 100.000 MHz   Register Stride: 256 bytes   Instance Stride: 4 bytes Configuration pin-out: IO Connections for TB3 -> 7I96_0 Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir TB3-1                   0   IOPort       InM              0        Input0          (In) TB3-2                   1   IOPort       InM              0        Input1          (In) TB3-3                   2   IOPort       InM              0        Input2          (In) TB3-4                   3   IOPort       InM              0        Input3          (In) TB3-5                   4   IOPort       InM              0        Input4          (In) TB3-6                   5   IOPort       InM              0        Input5          (In) TB3-7                   6   IOPort       InM              0        Input6          (In) TB3-8                   7   IOPort       InM              0        Input7          (In) TB3-9                   8   IOPort       InM              0        Input8          (In) TB3-10                  9   IOPort       InM              0        Input9          (In) TB3-11                 10   IOPort       InM              0        Input10         (In) TB3-13,14              11   IOPort       SSR              0        Out-00          (Out) TB3-15,16              12   IOPort       SSR              0        Out-01          (Out) TB3-17,18              13   IOPort       SSR              0        Out-02          (Out) TB3-19,20              14   IOPort       SSR              0        Out-03          (Out) TB3-21,22              15   IOPort       OutM             0        Output4         (Out) TB3-23,24              16   IOPort       OutM             0        Output5         (Out) IO Connections for TB1/TB2 -> 7I96_1 Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir TB1-2,3                17   IOPort       StepGen          0        Step/Table1     (Out) TB1-4,5                18   IOPort       StepGen          0        Dir/Table2      (Out) TB1-8,9                19   IOPort       StepGen          1        Step/Table1     (Out) TB1-10,11              20   IOPort       StepGen          1        Dir/Table2      (Out) TB1-14,15              21   IOPort       StepGen          2        Step/Table1     (Out) TB1-16,17              22   IOPort       StepGen          2        Dir/Table2      (Out) TB1-20,21              23   IOPort       StepGen          3        Step/Table1     (Out) TB1-22,23              24   IOPort       StepGen          3        Dir/Table2      (Out) TB2-2,3                25   IOPort       StepGen          4        Step/Table1     (Out) TB2-4,5                26   IOPort       StepGen          4        Dir/Table2      (Out) TB2-7,8                27   IOPort       MuxedQCount      3        MuxQ-A          (In) TB2-10,11              28   IOPort       MuxedQCount      3        MuxQ-B          (In) TB2-13,14              29   IOPort       MuxedQCount      3        MuxQ-IDX        (In) TB2-16,17              30   IOPort       SSerial          0        RXData3         (In) TB2-18,19              31   IOPort       SSerial          0        TXData3         (Out) Internal-TXEn          32   IOPort       SSerial          0        TXEn3           (Out) Internal               33   IOPort       SSR              0        AC Ref          (Out) IO Connections for P1 -> 7I96_2 Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir P1-01/DB25-01          34   IOPort       SSerial          0        TXEn2           (Out) P1-02/DB25-14          35   IOPort       SSerial          0        TXData2         (Out) P1-03/DB25-02          36   IOPort       SSerial          0        RXData2         (In) P1-04/DB25-15          37   IOPort       SSerial          0        TXData1         (Out) P1-05/DB25-03          38   IOPort       SSerial          0        RXData1         (In) P1-06/DB25-16          39   IOPort       SSerial          0        TXData0         (Out) P1-07/DB25-04          40   IOPort       SSerial          0        RXData0         (In) P1-08/DB25-17          41   IOPort       MuxedQCountSel   0        MuxSel0         (Out) P1-09/DB25-05          42   IOPort       MuxedQCount      0        MuxQ-A          (In) P1-11/DB25-06          43   IOPort       MuxedQCount      0        MuxQ-B          (In) P1-13/DB25-07          44   IOPort       MuxedQCount      0        MuxQ-IDX        (In) P1-15/DB25-08          45   IOPort       MuxedQCount      1        MuxQ-A          (In) P1-17/DB25-09          46   IOPort       MuxedQCount      1        MuxQ-B          (In) P1-19/DB25-10          47   IOPort       MuxedQCount      1        MuxQ-IDX        (In) P1-21/DB25-11          48   IOPort       MuxedQCount      2        MuxQ-A          (In) P1-23/DB25-12          49   IOPort       MuxedQCount      2        MuxQ-B          (In) P1-25/DB25-13          50   IOPort       MuxedQCount      2        MuxQ-IDX        (In) asis@192:~$
this now it's work ?
I have 1 more question.
How I can check for now it's can operate or can use input on 7i77 ?
Thank you
Asis,
3 years 2 months ago - 3 years 2 months ago #279276 by PCW
That pinout is correct for a 7I77
To test you need to make sure the 5V supply jumpers match on the 7I96S and 7I77
Either:
7I77 W5 LEFT
7I96S W6 UP
(7I96S supplies 7I77 5V)
Or:
7I77 W5 RIGHT
7I96S W6 DOWN
(7I77 Gets 5V from TB1)
Then connect the 7I77 to the 7I96S P1 with a DB25M/IDC26 cable
supply field power to the 7I77 and start LinuxCNC
Last edit: 3 years 2 months ago by PCW.
3 years 1 month ago - 3 years 1 month ago #280071 by abdulasis12
Either:
7I77 W5 LEFT
7I96S W6 UP
Or:
7I77 W5 RIGHT
7I96S W6 DOWN
Hi
I have question
When open PNCCONF  on page config MESA CARD 0
I choose Board : 7i96s internal Data
but Firmware not have 7i96s_7i77   , it's have 7i96s_7i74, 7i96s_d , 7i96s_dpl  only.
How I get Firmware for 7i96s_7i77 ?
Last edit: 3 years 1 month ago by abdulasis12.
3 years 1 month ago #280111 by PCW
I would create a configuration for a 7I92+7I77
and then change the card name in the .ini file from 7i92 to 7i96s
That should create a working 7I96S + 7I77 configuration
