- Thank you received: 6
A little help understanding what's going on with the pncconf wizard...
- Sparkman61
- Topic Author
3 years 1 month ago #281732
by Sparkman61
Replied by Sparkman61 on topic A little help understanding what's going on with the pncconf wizard...
I think I should have prefaced the following errors with:
I am getting a "hm2/hm2_7i96s.0: error finishing read" error. I didn't notice this until after reloading Linux on this box. I just spent the last hour reading the back and forth forum.linuxcnc.org/27-driver-boards/4691...error-finishing-read which I must say is very entertaining but not encouraging. I've got a few things to confirm and check out on that box and then I'll get back to everyone on this.
3 years 1 month ago #281734
Replied by PCW on topic A little help understanding what's going on with the pncconf wizard...
OK that's different, that means the the Ethernet latency is bad enough to cause
multiple sequential dropped packets.
Did you run a standard latency test?
What does:
uname -a
report
Whats does
ping 10.10.10.10
report?
What does:
uname -a
report
Whats does
ping 10.10.10.10
report?
- Sparkman61
- Topic Author
3 years 1 month ago #281740
by Sparkman61
Take a gander.
3 years 1 month ago - 3 years 1 month ago #281743
That does not look terrible though you may be better off with a newer
(say 6.4 or 6.5) kernel.
Can you run LinuxCNC and print the results of:
halcmd show param *.tmax
Last edit: 3 years 1 month ago by PCW.
- smc.collins
- Thank you received: 139
3 years 1 month ago #281749
by smc.collins
Replied by smc.collins on topic A little help understanding what's going on with the pncconf wizard...
that's absolutely not a good thing and should be correctedsee my advice above.
units in Pncconf are in per minute
units in the INI are per second
960 Inches per minute = 16 inches per second x 60 seconds
Pncconf writes the INI from your selections.
Pncconf defaults to 60 inches a minute (if you are using imperial, something close in metric) which is 1 inch per second.
- Sparkman61
- Topic Author
3 years 1 month ago #281759
by Sparkman61
Not until tomorrow - not sure I would know how to install a different kernel...
Time to create page: 0.064 seconds
