Probe for corner
13 years 3 months ago #36373 by BigJohnT
Replied by BigJohnT on topic Probe for corner
So much for that guess...
JT
13 years 3 months ago #36374 by BigJohnT
Are you getting the error on this line?
G38.5 F#1 Y-.010 (retract till probe clears)
JT
13 years 3 months ago #36375 by cwmk577
Replied by cwmk577 on topic Probe for corner
John, not 100% sure. I guess I should print it out and try stepping through it one thing at a time.
Where would I look to see what those variables' values (e.g. #5070) are? There's an emc.var file in my machine directory, but it doesn't have any lines for values under 5161 or something like that.
FWIW I tried the center probing routine that was posted earlier in this forum, and that worked fine....
13 years 3 months ago #36393 by Rick G
Replied by Rick G on topic Probe for corner
Hello,
Take a look here ...
linuxcnc.org/docs/html/gcode/gcode.html#sec:G38-probe
Try increasing the
#<Probepause> = #17 (=.05 pause) ; Probe pause, amount of time to pause between probe moves to wait for probe to settle/ stop bouncing
also try reducing
#<Fastprobe> = #1 (=10 Fast prb) ; Fast probe speed
#<Slowprobe> = #2 (=5 Slow prb) ; Slow probe speed
It looks like an early version is posted but this may help...
#<Probedist> = #3 (=.50 Prb dis) ; Probe distance
#<Retract> = #4 (=.050 Prb ret) ; Probe retract distance
#<Diam> = #5 (=.117 Prb Diam) ; Probe diameter
#<Xcord> = #6 (=.25 X Pcord) ; future ignore
#<Ycord> = #7 (=.25 Y Pcord) ; future ignore
#<Xcorr> = #8 (=0.00 X cor) ; correction to X coordinate to fine tune result
#<Ycorr> = #9 (=0.00 Y cor) ; correction to Y coordinate to fine tune result
#<Zcorr> = #10 (=0.00 Z cor) ; correction to Z coordinate to fine tune result
#<Ymax> = #11 (=1.00 Y Smax) ; maximum distance to search for Y
#<Yinc> = #12 (=.125 Y S inc) ; size of step to search in Y
#<Xfin> = #13 (=0.00 X fin) ; X Location to go to when finished
#<Yfin> = #14 (=0.00 Y fin) ; Y Location to go to when finished
#<Zfin> = #15 (=.125 Z fin) ; Z Location to go to when finished
#<Zsafe> = #16 (=.250 Z Safe) ; Safe Z travel location
Rick G
13 years 3 months ago #36428 by Rick G
G4 P#17
G38.3 F#1 Y[0 - #4] (retract to set up for slow probe)
G4 P#17
O103 IF [#5070 gt 0]
(MSG, Probe not complete unexpected Y hit on retract)
G90
M2
O103 ENDIF
If this is where you are having a problem it is possible that the probe is bouncing on and off on the retract steps.
A slower speed may help or you could try to retract with a G1 move instead. The G38.5 and G38.3 retract moves are for safety and information if there is an unexpected contact or the probe sticks.
You could also try changing the Y-.010 to Y -.025.
Rick G
13 years 3 months ago #36449 by cwmk577
Thanks. I tried changing the delay but it had no effect. I think the G38.5 was the problem. By the time I was done I ended up writing my own version of this using G1 moves and it seems to be working well. IIRC, LinuxCNC errors if the probe is tripped during a G1 move, or is that only when the G1 is issued from the MDI? I haven't tried tripping it during a programmed G1 move.
Time to create page: 0.334 seconds
