- Thank you received: 3
Gscreen 4th axis DTG wrong
10 years 10 months ago #66283
by LAIR82
Gscreen 4th axis DTG wrong was created by LAIR82
Finally got our 4th axis running on out machine and realized that the DTG column for the A axis is showing the actual position, not the distance to go.
Any thoughts?
Rick
Any thoughts?
Rick
10 years 10 months ago #66311
Replied by cmorley on topic Gscreen 4th axis DTG wrong
what version of linuxcnc and what version of gscreen please.
It could be code that needs adjusting or an update in the GLADE file.
Chris M
Chris M
10 years 10 months ago #66313
by LAIR82
Replied by LAIR82 on topic Gscreen 4th axis DTG wrong
Not sure on what version of gscreen, but I am using 2.7.3.
How do I find the version of gscreen?
Rick
Rick
10 years 10 months ago #66315
I'm sure you are using the default screen then (I really should have named it differently)
The other two common ones are gaxis and industrial.
OK I will look into it as soon as I can - this weekend
Chris M
Chris M
10 years 10 months ago #66316
by LAIR82
Oh, no it is the Industrial version,
I was looking for a version number, don't know why
No problem, it isn't really a big deal right now any way, we won't even be making any test cuts until monday or tuesday, and even then, we still won't be needing it,
Rick
Rick
10 years 10 months ago #66341
ok I see the error, it's in the glade file.
if you load the glade file for industrial and click on the HAL_DRO dto for the a axis,
reference type should be 2 not 1 (on the properties side bar on the right)
then resave. - an update of linuxcnc will over write this fix.
If you save the glade file in your config folder the change will be permanent.
That will fix it for now I will push the fix on the weekend.
Let me know of anything else that could be better or fixed.
Chris M
Chris M
Time to create page: 0.250 seconds
