- Thank you received: 3
Gscreen force to mm and homed
10 years 6 months ago #73502
by terkaa
Gscreen force to mm and homed was created by terkaa
I would like to know if it is possible to force mm/inch button to mm mode at loading Gscreen also I will be using absolute encoders do I would like to be "homed" at start. Any pins for these that can be set to 1 at HAL ?
Tero
Tero
10 years 6 months ago #73513
You might be able to just use NO_FORCE_HOMING in the INI file:
linuxcnc.org/docs/2.7/html/config/ini-config.html#_traj_section (bottom of the [TRAJ] section.
You can configure immediate homing by setting home search and home latch velocities to zero for each axis.
That still needs you to press the "Home" button, but there is a HAL pin for that too, which could be linked to the machine-on signal or similar.
Replied by andypugh on topic Gscreen force to mm and homed
terkaa wrote: I will be using absolute encoders do I would like to be "homed" at start. Any pins for these that can be set to 1 at HAL
10 years 6 months ago - 10 years 6 months ago #73514
by terkaa
Replied by terkaa on topic Gscreen force to mm and homed
Ok,
What is this Hal pin that can be used for this? (I believe that was the actual question here
Tero
Tero
Last edit: 10 years 6 months ago by terkaa.
10 years 6 months ago - 10 years 6 months ago #73517
halui.joint.N.home
Part of halui: linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
halui runs in userspace, so be aware that it isn't ideal for time-critical functions. But auto-homing isn't time-critical.
terkaa wrote: What is this Hal pin that can be used for this? (I believe that was the actual question here
halui.joint.N.home
Last edit: 10 years 6 months ago by andypugh.
The following user(s) said Thank You: terkaa
10 years 6 months ago #73518
by terkaa
Ok,
This is good info. Now I still have figure out how to make mm default and disable inch button. I believe it is time to learn some glade UI...
Tero
Tero
10 years 6 months ago - 10 years 6 months ago #73519
What do you have in [TRAJ]LINEAR_UNITS ?
I would have expected the GUI to look at that.
Time to create page: 0.057 seconds
