Gscreen force to mm and homed
10 years 6 months ago #73520 by terkaa
There is mm/inch button on top right corner of Gscreen. I believe it affects only to DRO readings. Inches are not needed here so it will only cause confusion if I leave it there....
Tero
10 years 6 months ago #73554 by terkaa
Ok, so I changed mm/inch button from visible to unvisible with Glade and toggled metric from Gscreen preferences. That made the trick there. Modding hal file like this made homing unneeded:
net x-is-home halui.joint.0.home halui.joint.1.home halui.joint.2.home halui.joint.5.home halui.machine.is-on
Tero
Time to create page: 0.164 seconds
