Python interface states of the home switches?
cmorley wrote: AttributeError: Pin 'panelinterface.pyvcp.rapid-machine-zero' does not exist
maybe:
AttributeError: Pin 'panelinterface.pyvcp.rapid-machine-zero' does not exist in the component panelinterface.
would be better?
Chris M
I've not really followed this thread, but to me, you are adding verbosity for no reason. Doesn't:
Say the same thing? It clearly identifies the component where the pin lives.
rodw wrote: I've not really followed this thread, but to me, you are adding verbosity for no reason. Doesn't:
That's the point. It's clear to you, but it wasn't clear to the original poster.
The new phrasing would be clear to both you _and_ the OP. So I think that's a win.
Bear in mind, rodw, that you are now a LinuxCNC expert and what is obvious to you now wasn't always so.
The issue is that the error message says the pin doesn't exist (actually it does exist if we consider the full path to the pin).
I would have better understood the error message if it was something like:
SomeError: Pin 'panelinterface.panelinterface.pyvcp.rapid-machine-zero' does not exist
When you check the status of a pin from inside a Python component you must not provide the component name itself.
andypugh wrote: Bear in mind, rodw, that you are now a LinuxCNC expert and what is obvious to you now wasn't always so.
Maybe so, but I learnt very quickly how to identify missing pins because I took the time to study the error messages and look for clues. No offence to the OP but sometimes I think people on this forum want solutions laid out on a platter and don't stop, analyse and think for themselves.
Sure I still get stuck and ask for help but not before I've had a go at it myself, just like I did in my early days. I still use hal code, Todd wrote for me right at the beginning when I was trying something cool but could not get it working. I was blown away by his generosity.
And I'm only an expert on a very small corner of the LinuxCNC ecosystem. So much more to learn. Whats a spindle for instance!
Here you go: spindle. The definition of a spindle is a thin rod used for spinning, or a yarn measurement. An example of a spindle is what sewing thread is spun around. An example of a spindle is 15,120 yards of cotton yarn.
:evil:
