LinuxCNC with DevFoamWing
7 years 4 weeks ago #146944 by andypugh
Replied by andypugh on topic LinuxCNC with DevFoamWing
jeffgar2000@gmail.com wrote: 2) On slopes, it runs a line of GCode, pauses, runs the next, pauses, etc, etc. You can hear and see the motors run, run, run, run instead of just running from one end to the other.
This is because your G-code begins with a G61
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g61-g61.1
Try G64 instead.
7 years 4 weeks ago #146981 by jeffgar2000@gmail.com
Probably worse, they are G1s
G1U21.0104V18.9463X20.8698Y61.2523
G1U21.9144V19.1432X21.7883Y61.3637
G1U22.8202V19.3391X22.7084Y61.4738
G1U23.7260V19.5351X23.6286Y61.5840
G1U24.6306V19.7293X24.5474Y61.6926
G1U25.5352V19.9236X25.4663Y61.8013
G1U26.4414V20.1168X26.3866Y61.9088
G1U27.3463V20.3098X27.3056Y62.0161
G1U28.2527V20.5019X28.2260Y62.1224
G1U29.1579V20.6937X29.1451Y62.2286
G1U30.0646V20.8846X30.0658Y62.3336
G1U30.9715V21.0754X30.9866Y62.4386
G1U31.8772V21.2646X31.9060Y62.5421
G1U32.7843V21.4540X32.8269Y62.6457
G1U33.6903V21.6419X33.7465Y62.7478
G1U34.5965V21.8296X34.6663Y62.8498
G1U35.5027V22.0173X35.5860Y62.9517
G1U36.4102V22.2039X36.5071Y63.0525
G1U37.3179V22.3905X37.4283Y63.1532
G1U38.2244V22.5755X38.3482Y63.2524
7 years 4 weeks ago #146982 by jeffgar2000@gmail.com
I thought the CM thing too but can't find anything that looks like that anywhere. I will get the ini file and hal posted soon. I lost my network out to the shop so I need to grab a thumb drive and run out there to get it.
7 years 4 weeks ago #147067 by andypugh
G1 is correct. But there was a G61 at the very top of the file, which puts the machine in "exact stop" mode (it's a modal code)
7 years 4 weeks ago #147075 by jeffgar2000@gmail.com
You are correct. I missed that. Other than that and the scaling being a little odd x10 it is running really well. I think we will run it a while and see what shakes out.
Thank you all for helping get to this point.
7 years 4 weeks ago #147088 by andypugh
As for the x10 thing, is it making things 10x bigger than the G-code or is the G-code 10x bigger than the model?
Time to create page: 0.111 seconds
