rigid tapping g33.1 isnt working spindle isnt sync
13 years 1 month ago #38394 by PCW
Typing "halcmd show pin" in a terminal window will dump
all hal pins and their states (and you can of course re-direct this output list to a file)
Looking back I notice that the your index is not synchronized with the actual spindle (This is a very unusual setup so its not surprising that motion may not like what it sees) It may be the fact that motion spindle revs is not commensurate with the index operation causes a problem
13 years 1 month ago #38395 by fabworx
hmmm ok what would you suggest to tie the index to the spindle cause the resent post of my hall I've deleted the gearchange. I'm leaving the gearbox in high gear which is 1:1 with the motor so as far as everyone is concerned the encoder might as well be mounted right to the spindle.
13 years 1 month ago #38396 by fabworx
im heading out to make it hang lol and get the halcmd show pins
13 years 1 month ago - 13 years 1 month ago #38400 by fabworx
ok so im thinking Im using the wrong pins to do my spindle at speed comparison. should I use the motion.spindle-in and motion.spindle-out as a comparison? if so ill need to scale my hm2_5i20.00.encoder.04.velocity pin prior to hooking it up to motion.spindle-in
Last edit: 13 years 1 month ago by fabworx.
13 years 1 month ago #38402 by fabworx
by the way I cant get halcmd show pins to work in the terminal window.
13 years 1 month ago #38404 by fabworx
oh and just for reference I thought this was odd. maybe I'm wrong I thought hm2_5i20.0.encoder.04.velocity was supposed to float out revolutions per second and its not. its putting out a number that is exactly 1000 times to small it says 0.506 to 0.507 with a s500 m3 running
Time to create page: 0.059 seconds
