How to configure a XHC-WHB04B pendant ?
5 years 9 months ago - 5 years 9 months ago #195978 by alkabal
Thanks a lot
So if i understand correctly with trivial kinematics the teleop mode is used only if machine is not homed ?
You mean after machine is homed this is no more used.
Signal managed by pendant is :
net pdnt.mode.is-auto net pdnt.mode.is-manual net pdnt.mode.is-mdi net pdnt.mode.is-teleop net pdnt.mode.is-joint
from Lcnc manual i see
halui.mode.teleop bit in : pin for requesting coordinated jog mode
So at the end i have not really understand what is really needed what is really needed.
Original component for machinekit did not use teleop mode at all, when i have start the conversion for Linuxcnc i get mpg working only using teleop mode, now i think this is maybe because i use a not homed machine for test ???
Last edit: 5 years 9 months ago by alkabal.
5 years 9 months ago #196017 by alkabal
Another test done with machine homed and you are right pendant work very fine without the use of teleop, so i will now check for update the driver and remove or use teleop only if machine is not homed.
Br
5 years 9 months ago - 5 years 9 months ago #196033 by alkabal
If some user are able to compile i have ask a PR for updated driver.
github.com/LinuxCNC/linuxcnc/pull/1049
hal config need to be restored :
net pdnt.mode.is-teleop halui.mode.is-teleop whb.halui.mode.is-teleop
hal config you need to add :
# "is-homed" axis signal for allowing pendant when machine is not homed net pdnt.axis.X.is-homed halui.joint.0.is-homed whb.halui.joint.x.is-homed net pdnt.axis.Y.is-homed halui.joint.1.is-homed whb.halui.joint.y.is-homed net pdnt.axis.Z.is-homed halui.joint.2.is-homed whb.halui.joint.z.is-homed
5 years 9 months ago #196249 by andypugh
alkabal wrote: Original component for machinekit did not use teleop mode at all,
That could be because Machinekit does not have the Joints-Axes changes, which separates the concepts of joints and axes (and adds separate jog inputs for both)
The following user(s) said Thank You: alkabal
5 years 9 months ago - 5 years 9 months ago #196280 by alkabal
I know yes you are right but i have also check the driver for older unit and see nothing about changind mode.
github.com/LinuxCNC/linuxcnc/blob/master...er_comps/xhc-hb04.cc
I have push code to Github for manage both case (homed/unhomed)
5 years 3 months ago #215595 by MRx
I just debugged this part and it doesn't seem to work as expected. it will set teleop mode permanently (even before homed) here and I cannot drive beyond the designated area.
Does anyone know what the reason is why the pendant only works in teleop mode?
I checked the sourcecode and the implementation is certainly not correct right now.
Time to create page: 0.430 seconds
