- Thank you received: 167
No idea about the CRC, I rarely use Modbus/RS485 except to program Schnieder VFDs. I'd assume it does or it'd be fairly useless.Yeah I'm trying exactly that. Took the vfd out of the wiring cabinet and with me into the office. Tested different programs, thanks for mentioning qmodbus. I even took the control board apart to see if there is maybe an error in the manual and the modbus is using other pins of the RJ45 connector than the mentioned pins 1 and 2. But after some fiddling and testing different pins I'am sure pin 1 and 2 are the right pins. Because thats the only combination where I even get ay RX signal. But no matter what I'm doing the only response I get is 00. I also contacted the tech support of the vfd.
P.S. do you know if qmodbus is sending CRC16 after each command?
