Spindle keep accelerating
1 year 7 months ago #324758 by vibram
Hello,
I built my HAL file with bits taken from the forum and for sure sometimes I don't understand everything.
THis results in the current situation where when I run my Gcode, for example M3 S500, the spindle is going faster and faster and never stops
Signal spindle-at-speed is true before running gcode, then it goes false and never go back to true.
My encoder is working properly with the correct number of pulse.
Maybe the near part is wrong but I have no clue if it's the case, and if yes, why ?
Thank you for your help
Here is the spinde part of my HAL file
#  SPINDLE
setp   pid.s.Pgain     [SPINDLE_0]P
setp   pid.s.Igain     [SPINDLE_0]I
setp   pid.s.Dgain     [SPINDLE_0]D
setp   pid.s.bias      [SPINDLE_0]BIAS
setp   pid.s.FF0       [SPINDLE_0]FF0
setp   pid.s.FF1       [SPINDLE_0]FF1
setp   pid.s.FF2       [SPINDLE_0]FF2
setp   pid.s.deadband  [SPINDLE_0]DEADBAND
setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm-abs     => pid.s.command
net spindle-vel-fb-rpm-abs-filtered      => pid.s.feedback
net spindle-output        <=  pid.s.output
net spindle-revs             <=   hm2_7i96s.0.encoder.00.position
net spindle-vel-fb-rps       <=   hm2_7i96s.0.encoder.00.velocity
net spindle-vel-fb-rpm       <=   hm2_7i96s.0.encoder.00.velocity-rpm
net spindle-index-enable     <=>  hm2_7i96s.0.encoder.00.index-enable
# setp hm2_7i96s.0.pwmgen.00.scale 2500
setp   hm2_7i96s.0.pwmgen.00.scale [SPINDLE_0]MAX_OUTPUT
# setp hm2_7i96s.0.pwmgen.00.output_type 1
#net spindle-vel-cmd-rpm     => hm2_7i96s.0.pwmgen.00.value
net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  spindle.0.speed-out
net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs
net spindle-enable             <=  spindle.0.on
net spindle-enable             =>  hm2_7i96s.0.pwmgen.00.enable
net spindle-cw                 <=  spindle.0.forward
net spindle-cw                    => hm2_7i96s.0.ssr.00.out-01
net spindle-ccw                <=  spindle.0.reverse
net spindle-ccw                    => hm2_7i96s.0.ssr.00.out-02
net spindle-brake              <=  spindle.0.brake
net spindle-revs               =>  spindle.0.revs
net spindle-at-speed           =>  spindle.0.at-speed
net spindle-vel-fb-rps         =>  spindle.0.speed-in
net spindle-index-enable      <=>  spindle.0.index-enable
sets spindle-at-speed true
net spindle-vel-cmd-rps    =>  near.0.in1
net spindle-vel-fb-rps         =>  near.0.in2
net spindle-at-speed       <=  near.0.out
setp near.0.scale 1.000000
setp near.0.difference 1.666667
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rpm => abs.spindle.in
net spindle-vel-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-vel-fb-rpm-abs-filtered lowpass.spindle.out
net spindle-output => hm2_7i96s.0.pwmgen.00.value
# ---Setup spindle encoder---
setp hm2_7i96s.0.encoder.00.scale 4000
1 year 7 months ago - 1 year 7 months ago #324780 by PCW
Replied by PCW on topic Spindle keep accelerating
What are the spindle P terms (in the ini file)
In general for spindle setup, I would get open loop operation
running correctly first before trying to close the loop.
Basically if you have a spindle PID loop, this means setting
FF0 to 1  and all other PID gains to 0
Last edit: 1 year 7 months ago by PCW.
1 year 7 months ago #324783 by vibram
Replied by vibram on topic Spindle keep accelerating
Hello PCW, thank you for your reply
Here is my ini file regarding spindle:
[SPINDLE_0]
P = 1
I = 0.01
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2500
When i just run the MDI command M3 S500, everything is fine
But when I run a gcdoe file with the same command, I get this issue
1 year 7 months ago #324787 by PCW
What is the sign of the PWM value when it runs away?
I think there is a runaway possibility with that hal setup when you reduce
the spindle speed enough that you get a negative PID output (which is treated
as a positive by the PWM hardware so instead of the spindle slowing down, it speeds up)
This _may_ be fixable by setting the PWM mode to 2 (UP/DOWN) so you get 0 output
when given a negative command. Another way would be to limit the PID output to
positive values.
1 year 7 months ago #324790 by vibram
How is it possible to monitor pwm sign in order to answer your question?
1 year 7 months ago - 1 year 7 months ago #324812 by vibram
when output type set to 2, the spindle is not moving at all.
when out put is 1, another strange thing, with command M3 S100, I directly got this:
I ask 100RPM and get 3.3 rps hence 200rpm
I checked the spindle.0.revs and it's correct, when I do 1 full turn, it's correctly recorded. This is strange
Last edit: 1 year 7 months ago by vibram.
Time to create page: 0.167 seconds
