linuxcnc-2.7-wheezy.iso actually distribution update errors
7 years 6 months ago #130714 by HolgerT
as TKR confirms my fears about usage of RT-PREEMPT and AnnoyingMutt shared links to wheezy sources,
so I'll use wheezy with edited /etc/apt/sources.list (attached the edited list - unzip before use). This works fine.
To get it working give the commands (in terminal):
cd /path/to/your/new/sources.list sudo mv /etc/apt/sources.list /etc/apt/sources.list.orig sudo cp sources.list /etc/apt/sources.list cat /etc/apt/sources.list sudo apt-get -o Acquire::Check-Valid-Until=false update
Check-Valid-Until=false is needed, because some release file has been expired.
br
Holger
The following user(s) said Thank You: Blackwind
7 years 6 months ago #130777 by richard123
I need to make some changes in the kinematics file so it will suit my corexy system. It means I have to be able to install linuxcnc -dev. Is this process can be done with this version of linuxcnc and debian iso file?
7 years 6 months ago #130778 by richard123
partec wrote: Live/Install for Debian Stretch, RT-PREEMPT, LinuxCNC 2.7.x
www.linuxcnc.org/testing-stretch-rtpreem...uspace-amd64-r13.iso
works fine including use of samba
LPT with Axis works perfect
for installing CamPY for LinuxCNC - Camera Edge Finder
as nicbit wrote in category debian-stretch-tricks
please install python-apt using the command:
sudo apt install python-apt
works perfect
7 years 6 months ago - 7 years 6 months ago #131097 by Blackwind
HolgerT wrote: Hi,
br
Holger
i think this is in the correct path to solution, but i have a lots of errors on updating.
somewhere i read that one has to make the Check persistent doing:
sudo "your preferred editor" /etc/apt/apt.conf
add a line to it (if apt.conf is not present this will create one)
LINE
Acquire::Check-Valid-Until "0";
LINE
after that
sudo apt-get update
my actual sources.list look like this
deb archive.debian.org/debian/ wheezy main non-free contrib
deb-src archive.debian.org/debian/ wheezy main non-free contrib
deb archive.debian.org/debian-security/ wheezy/updates main non-free contrib
deb-src archive.debian.org/debian-security/ wheezy/updates main non-free contrib
# wheezy-backports
#deb ftp.us.debian.org/debian/ wheezy-backports main contrib non-free
#deb-src ftp.us.debian.org/debian/ wheezy-backports main contrib non-free
The wheezy backports was used to install mate desktop, i have to comment it not knowing how to do it right ;(((
regards rick
Last edit: 7 years 6 months ago by Blackwind.
  • AnnoyingMutt
  • New Member
  • New Member
7 years 6 months ago #131101 by AnnoyingMutt
Lets just have one solution, confirmed by Adin/Mods and make it sticky and leave it at that.
7 years 6 months ago #131411 by csa
I have next lines in /etc/apt/source.list:
deb http://linuxcnc.org wheezy base 2.7-rtai deb-src http://linuxcnc.org wheezy base 2.7-rtai deb http://archive.debian.org/debian-security/ wheezy/updates contrib non-free main deb-src http://archive.debian.org/debian-security/ wheezy/updates contrib non-free main deb http://archive.debian.org/debian/ wheezy contrib non-free main deb-src http://archive.debian.org/debian/ wheezy contrib non-free main
And I added one file with name: "10no-check-valid-until" in /etc/apt/apt.conf.d/ with below line inside:
A restart may be necessary.
This works for me, hope this help.
BR,
Ciprian
Time to create page: 0.185 seconds
