[solved] Anybody using a MINI PCIe-to-PCI adapter?
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
18 Dec 2020 09:10 - 18 Dec 2020 09:12 #192310 by Aciera
I'm trying to set up a DELL Optiplex 7010 USFF. As I need a PCI connector for my hardware and the MB of this PC only has a miniPCIe connector:
I thought I'd try to use an adaptor like this:
www.delock.com/produkte/G_41359/merkmale.html
However I can't get it recognized and it does not show up in $ lspci at all.
Has any body successfully used one of these adapters for the miniPCIe?
Last edit: 18 Dec 2020 09:12 by Aciera. Reason: Add pic
  • Moderator
  • Moderator
18 Dec 2020 10:10 #192318 by tommylight
Replied by tommylight on topic Anybody using a MINI PCIe-to-PCI adapter?
I do recall someone using it (Beagle maybe ??), but in general they should work, the only things messing it up are:
-the cable, low quality ones will not work due to very high frequencies going through them
-PCI-E generational differences
To test this, see if you can set the PCI-E gen to 1 and reboot. That will use the lowest speed for communication but it should still be more than enough for everything, except 1GB network or graphic card or storage.
  • Aciera
  • Administrator
  • Administrator
18 Dec 2020 12:38 - 18 Dec 2020 12:38 #192326 by Aciera
Ok, after I noticed that the PCI Bridge got recognized in the BIOS I decided to reset the BIOS to default and restarted.
And bingo, it works!
Last edit: 18 Dec 2020 12:38 by Aciera.
18 Dec 2020 13:58 #192331 by dm17ry
i recently played with the hp 6300 sff, and i remember where was an option in the "security" menu of the bios setup to disable various things including PCI, PCIe slots. maybe the same with the dell?
  • Moderator
  • Moderator
18 Dec 2020 17:49 #192357 by tommylight
Those are "Enterprise" PC's and as such have more security features, like disabling the USB ports, while they have very little for adjusting and setting up we usually need, like disabling the utterly useless hyperthreading!
But on the positive side, they do have the best electronics parts found on PC's.
Time to create page: 0.198 seconds
