LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
2 years 7 months ago #297112 by acourtjester
2 years 7 months ago #297123 by acourtjester
Ok I have found how to place new buttons in the GUI , it is in the .Prefs file see attached screen shot. Installed and working as it should without errors.
Thanks still learning
2 years 7 months ago - 2 years 7 months ago #297160 by phillc54
This message:
Is telling you that you had the same code for buttons #5 and #11, "torch-pulse" is only allowed on one button.
You can add buttons in PnCconf and also on the SETTINGS tab of the GUI.
linuxcnc.org/docs/devel/html/plasma/qtpl...#plasma:settings-tab
linuxcnc.org/docs/devel/html/plasma/qtpl...:custom-user-buttons
Last edit: 2 years 7 months ago by phillc54.
2 years 7 months ago #297184 by acourtjester
 Thanks PhllIn my last post I did fine another way to install custom button that worked without error.  I did have another problem come up when I tried to convert the SheetCam tools to the Material file for the GUI.  I followed the manual and all look fine but then had another error on start of the GUI.  I have attached the screen shot of the error and the resulting material file.  Not sure if the GUI did not like some of the syntax in the file as it talks about different line in the file.  Maybe a type of tool I had in SheetCam does not convert well for the GUI/LinuxCNC.  Not sure if the .RAR  files are uploaded for you to see.
File Name: tom_test_material.rar
File Size:916 B
File Name: tomstools8-17-21.rar
File Size:1.45 KB
2 years 7 months ago #297187 by phillc54
I am sorry, that is a bug I have caused. image missing /media/kunena/emoticons/sad.png
To work around it, edit the .prefs file, change [GUI_OPTIONS]Default material to 1 rather than 0.
I will push a fix as soon as I get it done.
2 years 7 months ago #297188 by acourtjester
Thanks again Phill
I will give the a try in the morning.
Time to create page: 0.290 seconds
