LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
2 years 7 months ago #296431 by phillc54
Give this a try, in the [RS274NGC] section of the .ini file change:
./:../../nc_files/plasmac/m_files
to:
./:../../nc_files/examples/plasmac/m_files
2 years 7 months ago #296432 by acourtjester
made change and here is the end of the report
2 years 7 months ago #296434 by phillc54
That looks like some type of network issue to me, hm2_eth is to do with the ethernet for the mesa card.
2 years 7 months ago #296435 by acourtjester
I understand but I have do nothing to the connection to the mesa card.
Not sure if this means anything but a made a dummy Axis gui and it seem to load up fine. When I click on the wire connection a window in the upper right says it has established connection
There are LEDs on the mesa card showing communications. The connection on the card is showing a green and yellow LED on.
I had a WIFI card in the PC and have WEB service, I did not have that before this load of the new software, and it would start QTPLasmaC fine and would run it too. Maybe I should remove the WIFI card.
I am going to call it a night and go to bed
Thanks for your help
2 years 7 months ago #296436 by acourtjester
I did remove the WIFI card no change
This is another error that comes up too
2 years 7 months ago - 2 years 7 months ago #296443 by phillc54
That doesn't make sense, the path listed there should be the USER_M_PATH from the .ini file.
Are you using master branch (2.10) or 2.9 branch?
Can you post the result of this:
du -h ~/linuxcnc/nc_files/examples/
Edit: It seems that I have made a mistake with the expected location of the codes directory in package installations. I will try to fix it before the weekend if you can respond to the above two questions.
Last edit: 2 years 7 months ago by phillc54.
Time to create page: 0.063 seconds
