Third time's a charm?
4 years 9 months ago #232909 by milu
Third time's a charm? was created by milu
I thought my troubles were behind me, but I failed at getting a parallel port to work on my MSI-based PC. The good news is that Best Buy actually agreed to refund my money for the Dell and I was able to replace it with a Lenovo desktop. The 2.8.2 .iso installs on the Lenovo, but won't subsequently boot and actually has the same exact issue with Iwlwifi9000 as the Dell. So here's the score card:
Dell Inspiron 3880: 2.8.2 installs, but won't boot
MSI 2.8.2 installs, but parallel port doesn't work
Lenovo: 2.8.2 installs, but won't boot
Unless someone has a better idea, I'm going to try to install Debian 10, add a RT_PREEMPT kernel and Linuxcnc. This is the start of week 2 of trying to install linuxcnc.
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 9 months ago #232918 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Third time's a charm?
You really need to give more information regarding the MSI parallel port issue.
Unfortunately no one is a mind reader.
You haven't said whether the Parallell is on board, PCI or PCIe.
As much as forum members want to help, getting information from those wanting help can be like pulling, very painful & very slow.
Here's a thread about parallel ports.
forum.linuxcnc.org/18-computer/42826-par...-info-thread?start=0
So if you are willing & able to supply a bit more info the advice will be a lot better.
4 years 9 months ago - 4 years 9 months ago #232920 by milu
Replied by milu on topic Third time's a charm?
I haven't really given up on the parallel port option--today was just the last day I could return the dell (and super surprised they took it back). So I figured I would try the Lenovo and see where it leads.
I have three different parallel port cards. On the MSI, only one of them is detected during boot. I confirmed that with both dmesg and lspci -v. The correct parport directory structure is created with the correct entries for address and IRQ. It just never connects to the Gecko. I tried using the .hal parport tester and toggling those bits does not, for example turn on the charge pump on the Gecko. If the Lenovo doesn't work, I'll probably go back to that. But at least I have 45 days to mess around without losing money.
BTW: I am super grateful for the help I've received so far. Sorry if I sound a little jaded, but its been a little frustrating.
Last edit: 4 years 9 months ago by milu.
4 years 9 months ago #232923 by rodw
Replied by rodw on topic Third time's a charm?
If you are installing on new hardware, I'd be leaning towards Debian 11 (non-free) and master branch compiled from source per the QTPYVCP instructions.
This will give you a later kernel for more chance of hardware support.
The following user(s) said Thank You: milu
4 years 9 months ago #232926 by elf
Replied by elf on topic Third time's a charm?
Does the Lenova boot from the usb using the iso? If so, the boot menu should have an option to boot to the hard drive. My Debian 11 ended up in this state at one point. I ended up repartitioning the hard drive (actually SSD), installing Windows in one partition (Required to run Clearpath servo configuration.) and LinuxCNC (with the LinuxCNC iso) on another. It dual boots now with no problems,
4 years 9 months ago #232941 by tommylight
Replied by tommylight on topic Third time's a charm?
Some parallel port cards will not work with LinuxCNC as they are software emulated ports.
Some do work, and most do not require any drivers, they just work.
So far i had luck with MosChip/NetMos ones, all PCI ones work.
Time to create page: 0.345 seconds
