(solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
  • SertanATL
  • SertanATL's Avatar Topic Author
  • Junior Member
  • Junior Member
05 Apr 2022 13:44 #239335 by SertanATL
I am trying to install LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO to my HP 8300 Elite computer using usb stick.
Bios settings: Legacy Boot enabled, Secure Boot Disabled. EUFI is enabled, installer won't run on legacy.
While installing, installer crashes while IPV6 installation.
In order to avoid this problem I disconnected the pc from the internet. Now I get Install Fail: 'grub-efi-amd64' package failed to install into /target/ problem.
I created the usb stick using Win32 DiskImager and Rufus, no differance.
I read other topics about this but I could not find any solution.
I wanted to install Debian 7 Wheezy ISO but it does not boot at all.
I previously installed Mx19.4 and installed Linuxcnc but it had over 1.000.000 latency.
How do i install LinuxCNC?
05 Apr 2022 14:53 #239338 by tommylight
  • SertanATL
  • Junior Member
  • Junior Member
05 Apr 2022 17:23 #239363 by SertanATL
When I diable UEFI pc cannot boot to usb stick. It cant find something to boot to and sits on black screen. What am i doing wrong?
  • scotth
  • Elite Member
  • Elite Member
05 Apr 2022 17:40 #239364 by scotth
I have had some luck using the DD option in Rufus when ISO fails.
I don't know if it will help, but it has worked for me.
Look at
trendoceans.com/how-to-create-a-bootable...linux-distributions/
05 Apr 2022 20:40 #239383 by rodw
This is just another reason why I always use Debian Bullseye as the later kernel has UEFI support and a host of drivers for more recent hardware (and I use Rufus to make the usb stick)
Install instructions
www.qtpyvcp.com/install/bullseye.html
  • SertanATL
  • Junior Member
  • Junior Member
06 Apr 2022 06:20 #239416 by SertanATL
Thanks for the advice!
I tried DD option but no luck unfortunately.
06 Apr 2022 07:09 #239418 by rodw
If it helps, I burnt a copy of Debian Bullseye (11.3) nonfree to a DVD today and installed it on  a MSI  All in one i3 PC because it preferred  a DVD to boot to.
I installed the preempt_rt patch using synaptic (search for linux-image) and also linux-headers for that kernel while I was there.
Then instead of using the link I provided  earlier in this thread, I decided to use this script
github.com/joco-nz/lcnc-bullseye-installer
I realised then I needn't have bothered installing the preempt_rt image as the script  does it for you
It worked flawlessly. It asked a few questions along the way but when done, I had linuxcnc in the menus
The script was written by James who also wrote the instructions linked earlier so I expected it to be perfect!
The following user(s) said Thank You: SertanATL
  • SertanATL
  • Junior Member
  • Junior Member
06 Apr 2022 09:32 - 06 Apr 2022 09:34 #239426 by SertanATL
I downloaded latest Debian from their website and ran the script as you said and it worked flawlessly!
You are a great help rodw, thank you!
Edit: SOLVED!
Last edit: 06 Apr 2022 09:34 by SertanATL.
06 Apr 2022 13:03 #239442 by rodw
Great to see you got a result!
Debian Bullseye with a later kernel has a greater range of hardware support.
Its a nice system to use and worth the bit of extra effort to get up and running.
And to think you managed to install it based on on paragraph of instructions without wading through pages of instructions required for MX linux!
Time to create page: 0.065 seconds
