i don't have connection
  • isaac85
  • Topic Author
  • New Member
  • New Member
4 years 6 months ago #241386 by isaac85
i don't have connection was created by isaac85
Sorry i didn't found a solution to my problem.
I installed linuxcnc and the installer gave to me some problems.
i cannot install grub, although i found solution with this, and i cannot do the installation with connection, with wifi and eth neither
so i done the installation anyway but now i don't have connection.
i bought one wifi intel 9560, and the module is load i think "iwlwifi".
and i bought one mesa 7i95 and i cannot get connection too, and all the places i found for get this connection i need download some tools, but i don't have connection.
Someone had the same problem? maybe is a problem of networkmanager configuration? someone can help me? i have mounths with this problem and i cannot get a solution, i am new with this i cannot start to do this project.
and maybe i would like get some leasons about linuxcnc, find a teacher would be great, i can pay the leasons.
Thanks.
4 years 6 months ago #241388 by PCW
Replied by PCW on topic i don't have connection
1. What IP address is the 7I95 using? (192.168.1.121 or 10.10.10.10)
(10.10.10.10 is suggested)
2. What does the command
ip a
(typed in a terminal window)
return?
  • isaac85
  • Topic Author
  • New Member
  • New Member
4 years 6 months ago #241395 by isaac85
Replied by isaac85 on topic i don't have connection
i used 10.10.10.10
but the command ip a just return lo
not eth0
4 years 6 months ago #241433 by PCW
Did you try setting up the Ethernet with network manager?
What is the name of your Ethernet interface?
(it may well not be eth0)
  • isaac85
  • Topic Author
  • New Member
  • New Member
4 years 6 months ago #241440 by isaac85
the applet networkmanager in desktop not work, the letters are grey and i cannot click
i went to /etc/network/interfaces
and there i wrote:
auto eth0
iface eth0 inet static
address 10.10.10.10
netmask 255.255.255.0
gateway 10.10.10.1
But i think is a drivers problem because not detect, wifi and ethernet neither.
although iwlwifi and e1000 modules are charged.
i don't know...
  • Moderator
  • Moderator
4 years 6 months ago #241444 by tommylight
Replied by tommylight on topic i don't have connection
auto eth0
address 10.10.10.10
10.10.10.100
10.10.10.11
10.10.10.250
Anything BUT 10.10.10.10
  • isaac85
  • Topic Author
  • New Member
  • New Member
4 years 6 months ago #241701 by isaac85
i tried all this ip for address
but nop, not work
i tried install a usual debian in the same computer and it is giving to me the same problem.
so i am thinking use ubuntu or arch.
i will try install preempt-rt and linuxcnc there.
some suggest, advice or tip?
4 years 6 months ago - 4 years 6 months ago #241706 by rodw
Replied by rodw on topic i don't have connection
My guess is drivers required for your network interface do not exist in Debian Buster.
Tell us about your PC make, model, network interface if known
I would recommend you try to  install debian testing (bookworm) from this download
cdimage.debian.org/cdimage/unofficial/no...builds/amd64/iso-cd/
once installed (assuming the network driver is found) type these lines:
sudo apt update
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash
linuxcnc
Last edit: 4 years 6 months ago by rodw.
The following user(s) said Thank You: isaac85
  • isaac85
  • Topic Author
  • New Member
  • New Member
4 years 6 months ago #241731 by isaac85
Motherboard Biostar racing z490 gtn mini itx
socket 1200 with intel pentium gold cpu
lan Intel i219V
wifi intel wirless 9560
gpu radeon rx 550
i will try what you say.
but for the moment i installed arch with a kernel real time and linuxcnc work there.
i am new in linuxcnc and i must learn how work all the configs and hal...
do you think will be difficult make work 7i95 with arch?
Time to create page: 0.208 seconds
