Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
  • Cant do this anymore bye all's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Feb 2025 00:50 - 01 Feb 2025 04:59 #320270 by Cant do this anymore bye all
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!! was created by Cant do this anymore bye all
First lets talk about the images.
1: They are based on Debian repos built by a collection of custom scripts.
2: Whilst some images have been written to SD card via RPi Imager Balena Etcher is recommended.
2a: If you use Linux there are plenty of other tools, Ubuntu\Mint has USB Image writer.
3: If you use the RPi Imager any adding of user or wifi info does not work. As the image is a custom one, only the kernel is built from RPi Sources.
4: If you are using an Rpi5 & a 7c80 0r 7c81 the driver to be loaded is hm2_spix
5: If you are using an RPi4 & a 7c80 or 7c81 the driver to be loaded is hm2_rpsipi
6: The images now have the SPI interface enabled by default.
7: Location of config.txt  /boot/broadcom/config.txt once again this is a custom build.
8: raspi-config is not in the image, the tool to use is menuconfig.
9: The default username is cnc.
10: The default password is cnc.
11: The images are not meant to be a fully fledged daily driver Operating System, the are just enough to run Linuxcnc.
Links to images:
www.linuxcnc.org/iso/rpi-5-debian-bookwo...25-01-27-0140.img.xz
www.linuxcnc.org/iso/rpi-5-debian-bookwo...7-0140.img.xz.sha256
www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
www.linuxcnc.org/iso/rpi-4-debian-bookwo...7-0404.img.xz.sha256
Last edit: 01 Feb 2025 04:59 by Cant do this anymore bye all.
The following user(s) said Thank You: tommylight, elovalvo, ErwinCNC, MTTI, behai, bananun, Esz2
01 Feb 2025 01:27 #320273 by tommylight
Should we nail it ...hmmm pin it ? :)
And adding the download link would be good.
Thank you.
The following user(s) said Thank You: Cant do this anymore bye all, behai
  • Platinum Member
  • Platinum Member
01 Feb 2025 05:00 #320282 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Pinium it ;)
01 Feb 2025 05:30 #320288 by bananun
Thank you! Have you tried to install ethercat on these images? I can't get it to work. However on a older image (with older kernel) you have posted it works without issue.
  • Platinum Member
  • Platinum Member
01 Feb 2025 06:19 #320290 by Cant do this anymore bye all
You know, that's not really helpful at all. Why is it no one wants to give any info that may help others diagnose a problem ? It's like pulling teeth, some kind of demented game.
01 Feb 2025 22:30 #320360 by tommylight
Pinium it ;)
Done.
Thank you.
04 Feb 2025 03:56 #320558 by unknown
As of Feb 4th 2025 the the 6.12.xx series kernel is not supported by Ethercat, so installation will fail. Those wanting Ethercat are encouraged to use the previous version. This is one of the pitfalls of creating images, if a older kernel is used people get upset, if a newer kernel is used people get upset. Eevn if we had of used the Rpi kernel that is "current", 6.6.x series, Ethercat would have the same issue.
Rodw is on to it and has raised the issue on the github repo.
www.linuxcnc.org/iso/rpi-5-debian-bookwo...23-11-17-1520.img.xz
"Does not work" is useless without further information. We do not read minds, I at least don't like playing 1000 questions.
If you have issues writing the image to an SD card, try extracting the image from the downloaded file (don't ask me I don't use windows), as the file is compressed to save space and time downloading, then try writing the image. If that fails check the sha256 sum. Tho if the file is corrupt extracting file will likely fail anyway. So check it first.
The following user(s) said Thank You: behai
04 Feb 2025 04:30 #320565 by rodw
Only installation of Ethercat will fail. I have raised an issue with etherlabmaster on their gitlab repo asking if they have a time line for 6.12 support.
I alos pointed out they should get their finger out as Debian Trixie is only a few months away and it is currently running 6.12 :)
The following user(s) said Thank You: behai, bananun
04 Feb 2025 04:38 #320567 by unknown
Thanks for clearing that up Rod, it made sense in my mind, which was probably a bad sign. ;)
As a band aid solution I extracted the files from the ethercat-dkms package and ran the update script in the directory for the boardcom stuff, which is a pain as the whole linux sources are need, not just the headers. Anyways some of the patches failed so I gave up on the theory.
06 Feb 2025 21:11 - 26 May 2025 05:07 #320852 by unknown
Regarding GPIO drivers.
For the Rpi5 please use hal_gpio
For the RPi4 hal_pi_gpio or hal_gpio (this looks like the easier option to setup) , should be no need to mess with permissions
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
linuxcnc.org/docs/devel/html/drivers/hal_pi_gpio.html
Last edit: 26 May 2025 05:07 by unknown.
Time to create page: 0.222 seconds
