refclockSyncCycle question
2 years 2 months ago #307375 by papagno-source
Hi , at all.
in many example ethercat.xml configuration files, the values ​​of refClockSyncCycles are different.
Sometimes -1 , sometimes 1 , sometimes 5 .
If you use a servo period in the ini file of 1 ms , what is the correct value to use ?
Keeping in mind that appTimePeriod is 1000000
2 years 2 months ago #307414 by zmrdko
Replied by zmrdko on topic refclockSyncCycle question
5 should mean that clock is synced every 5 cycles. But its better to have first slave with refclock and -1 will let the first slave manage the clock referencing.
2 years 2 months ago #307467 by papagno-source
My refClock setting is 1.
I will try the value -1.
Sometimes, in a rare way, when LNCNC starts for the first ignition of the Lathe and after having turned on the auxiliaries, moving the X or Z axis, the axes shake.
I am forced to simply restart LNCNC and the problem at the next restart is no longer present.
It seems as if the ethercat BUS is not synchronized.
The drives are Delta ASD2,
2 years 2 months ago #307488 by papagno-source
I left the refClock value at -1 , but it gets worse.
The vibration problem is present at every restart of LNXCNC.
So I reset it to 1. It would probably be better to set it to 2 ?
2 years 2 months ago #308426 by papagno-source
By increasing the value of refClock to for example 5 ms, what actually happens, do I update the data on the bus every 5 ms or is the data updated every 1 ms of the appTimePeriod anyway?
2 years 2 months ago #308433 by zmrdko
IIRC 5 means every 5 cycles
Time to create page: 0.214 seconds
