Ethercath 1.6 workable or not?
2 years 1 month ago #309400 by bkt
Repo send to me continuos messages about upgrade to ethercat 1.6 ... but is workable or not? AN in witch SO?
thaks
2 years 1 month ago #309406 by onceloved
Yes, I have used 1.6 for a long time.
2 years 1 month ago #309772 by bkt
Replied by bkt on topic Ethercath 1.6 workable or not?
and in witch SO?
2 years 1 month ago #309786 by rodw
Replied by rodw on topic Ethercath 1.6 workable or not?
Try this script. I did ask the mods to sticky it
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
you might need to run sudo apt update afterwards as an existing ethercat user
Please post on that thread if it works for you
The following user(s) said Thank You: bkt
2 years 1 month ago #310058 by bkt
read inside .... well done and work for sure .... but is not mine problem now. Discover my LMDE6 install have some bug regards gcc version .... think I write somethings about in few hour .... so I made a new and conventional installation of Lcnc 2.9.0 with ethercat .... I have again problem with r8169 .... but become discover gcc problem become from 6.6 kernel, I go directly on 6.10 kernel .... just now installing see module not "generic" is skipped and not installed from linuxcnc-ethercat repo ..... so ask you if there is a method to install it whitout reinstall ethercat from git etherlab .....
If need to install again ethercat from etherlab git .... ask to you if is needed remove linuxcnc-ethercat .... aor need to reinstall it after installation process of etherlab 1.6.
2 years 1 month ago #310168 by rodw
the reinstall might overwrite your ethercat conf file.
I don't think the linuxcnc hal driver will be affected.
Time to create page: 0.411 seconds
