The files I'm trying to access are on a Windows 7 system attached to my home network through a router. Using the Linux File Manager, I can get to the files without any sort of mount commands. The files/folders are designated "shared" on the Windows system.
Most file dialogs used in programs come from the SDK from that language and populate their file trees simply from detected files using similar to a
ls command.
The more advanced file managers, especially those integrated into the system, do all sorts in the background.
They automatically mount your mobile phone through MTP using the /proc system, create a directory and mount inserted USB sticks onto it, automatically mount detected network shares etc etc
The killer for sharing from windoze to Linux, is very often the awful file names, full of spaces, multiple periods, asterisks, brackets or escaped sequences to try to overcome them if accessing in a browser.
In very many Linux programs a space precedes a new argument, a period precedes the extension as far as the parsers are concerned, so they cause problems
Anyone who has tried to download a video ripped by a windoze user, using wget on the commandline will know what I mean.
The safest word separation to use in a filename is an underscore _ . Even a dash - has dangers in some circumstances, where it is possible the name could be seen as an instruction to subtract one named variable from another.
As Todd pointed out you can automatically mount at boot if necessary, be aware of course that the networked drive MUST be available at EVERY boot, or you may hit other problems.
A slow boot is one possibility, already the newer kernels will wait for 1 1/2 minutes at boot up if they find an instruction in fstab to mount a drive by UUID which they cannot resolve.
(NB. Most common reason for this problem if you have it, is that the swap partition was reformatted when a new partition install was done and all the other partitions which mount that same swap, now have the wrong UUID in their fstab - bugged the hell out of me until I realised what was happening :laugh: )
