there's a great and good work behind gmoccapy, i love it. Thank you Norbert.
I'm referring to some bugs/improvements needed to get gmoccapy rock solid and with all the functionalities like PathPilot.
Probably the most of behavior are not related to gmoccapy itself but linuxcnc/gtk/etc.
Now i'm not aware on the last development of it so i can miss something, but for what i remember my list is:
- macro not showing correctly in gcode listing
- when editing the offset table we can change only one field at time
- add the ROT parameter to be set in the offset table
- when using probe_screen the page is forced to switch back to mainpage, sometime not.
- Probe screen should be improved (i was working on it but i'm on hold now)
- Gremlin should be improved. It should not reset the view automatically
- Goto gcode line is ok? last time i tried no
- little improvement to M6 remap: when tool is on dont go to change position
- i've not tested features from a long time. But to complete the list the gmoccapy+feature+probe with all the jingle and bells would be great and i would like it more than PathPilot
