External Coolant Controls
5 years 2 months ago #218188 by andypugh
Replied by andypugh on topic External Coolant Controls
but that doesn't work
How doesn't it work? Is there an error message?
5 years 2 months ago #218230 by davidimurray
No error message. Pathpilot starts fine. When I toggle the on screen button, I can see tormach.coolant change states, but the output from the MUX does not change. If i use my external switch then the MUX output does change.
5 years 2 months ago #218231 by andypugh
What is the state of the mux select inputs in the "auto" position? perhaps toemach,coolant needs to go to in-bit-03
5 years 2 months ago #218234 by davidimurray
I will have a play later when I get back from work and try changing the bit
5 years 2 months ago - 5 years 2 months ago #218431 by davidimurray
Hi Andy
Found the issue - it was this line -net coolant-flood mux-gen.00.out-bit => hm2_7i84.008a.output-08
As coolant flood is defined elsewhere it was trying to double allocate the signals - changed to coolantflood and now works with internal and external switch. Only thing it doesn't do is when using the external switch, the light does not illuminate on the on-screen switch
Thanks for your help
Last edit: 5 years 2 months ago by davidimurray.
Time to create page: 0.062 seconds
