- Thank you received: 167
Reassign Breakout Board pins in PathPilot?
2 years 5 months ago #301102
by blazini36
It'd be nice if there was some easier way to navigate the files other than the filenames.
Replied by blazini36 on topic Reassign Breakout Board pins in PathPilot?
No, the function of the pin is firmware, changing the purpose of the pin is done in firmware. As PCW mentioned there's a bunch of pre-made firmwares that you can usually download by going to the Mesa store and clicking "support software" for the card.Thanks! So if I'm understanding you right, I can swap step and dir pins in HAL, without firmware changes?
Or all changes require firmware changes to match?
The following user(s) said Thank You: Whitebarn
2 years 5 months ago #301103
by Whitebarn
Replied by Whitebarn on topic Reassign Breakout Board pins in PathPilot?
I have 3 Chinese 3040 routers, I don't have the board numbers. And I have a couple lathes that I'll be starting from scratch.
I posted my lathe questions before, and got no reply, so I put them on hold.
forum.linuxcnc.org/pathpilot/49554-nonto...oor-and-limit-inputs
2 years 5 months ago #301106
by Whitebarn
I can switch to a normal board and drives on the routers, not a big deal.
But, my biggest lathe problem is that freq2pin is assigned to a pin that is an output on bobs like cnc4pc C10
2 years 5 months ago #301108
by Whitebarn
Also I really appreciate your help, and the work you do!
2 years 5 months ago #301115
Replied by PCW on topic Reassign Breakout Board pins in PathPilot?
Do you have a DB25 pin number <--> function list
for the breakout board/machine functions you need?
Time to create page: 0.205 seconds
