- Thank you received: 994
tommylight wrote: Hey Bev,
that is for the plasma you are building right ?
You should add some cross members to make the table more rigid in the middle as if cutting thicker steel plates it will buckle in the middle with time.
That should do it! Seen to many of them bent to much to be useful.bevins wrote:
Yeah, I think I will add a cross beam with a leg in the middle, adjustable like the rest.
jason1098 wrote: Will you explain what you mean by "Air Holes in the frame" and what the purpose is and where they should be placed. I'm about to start my frame for my CNC plasma build and this is the first comment i've heard about adding air holes.
