How to cut thick material from edge
- thefabricator03
6 years 5 months ago #167896
by thefabricator03
Replied by thefabricator03 on topic How to cut thick material from edge
Just curious, why would the 5 axis head make a difference?
6 years 5 months ago #167898
Replied by tommylight on topic How to cut thick material from edge
A good machine Oxy torch will cut 160mm at quite nice finish requiring little after work. As with everything there are some "gotchas" working with it, most of it i do not know, unfortunately.
About 15 or so months ago i was working as a General Manager at a local factory dealing in metalwork for export to Austria, there was an employee there who knew everything about Oxy cutting, would not teach anyone even if his life depended on it! Miserable P. of $itt!
The machine i built for them has two separate fully functional Z axis, both with floating heads, one was used for plasma and the other for Oxy, i did quite successfully cut some 60mm material on it with more than respectful finish, just a quick angle grinder was needed to be perfect.
Preheat is very important, otherwise it ends up in strange shapes !
- thefabricator03
6 years 5 months ago #167903
by thefabricator03
How fast do Oxy machines move Tom? I would imagine very slowly, also how do they go with piercing?
- dvn4life1972
- Thank you received: 173
6 years 5 months ago #167904
by dvn4life1972
Replied by dvn4life1972 on topic How to cut thick material from edge
The trick with flame cutting is to not overrun the preheated area. Piercing isn't quite as simple as with plasma...gotta build up good preheat all around the pierce area to get through.
- thefabricator03
6 years 5 months ago #167906
by thefabricator03
Yeah I thought as much. I would imagine that a CNC oxy would be similar to a hand oxy with piercing. How do you go with the nozzles clogging up?
dvn4life1972 wrote: The trick with flame cutting is to not overrun the preheated area. Piercing isn't quite as simple as with plasma...gotta build up good preheat all around the pierce area to get through.
- dvn4life1972
6 years 5 months ago #167908
by dvn4life1972
I've never done it on a machine, always by hand. I would angle the torch head and wash the molten material away for piercing thick material.
Time to create page: 0.103 seconds
