using linuxcnc for laser fiber marking
5 years 2 weeks ago #223030 by PCW
OK that means the PID is not the issue.
It means the XY2-100 interface is outputting the numbers
that LinuxCNC commands within the following error limits
Maybe the error is in the interface, are you sure you have the clock and data polarity correct?
5 years 2 weeks ago #223067 by mahdi2001h
I used to use your configuration for testing, but now I have edited that configuration and now I know that my configuration was incorrect
this is my new config :
File Name: configs_20...0-14.zip
File Size:3.91 KB
with :
FERROR =    3
MIN_FERROR = 3
i have following error.
The error is related to my high speed!
What should I do to configure pid for high speed ?!
5 years 2 weeks ago #223073 by andypugh
My impression is that the squares are good, so G1 moves are working correctly at the feed rate that you are using.
So the issue seems to be with the G0 moves.
As a first step, try reducing the MAX_VELOCITY in the INI to closer to the same speed as the feed rate in the video. Then if that fixes the lossof position problem, increase it until the issue re-appears, Then back off slightly.
Galvos should be very repeatable, you don't need to worry about part mass, so you don't need much spare capability.
5 years 2 weeks ago #223105 by PCW
First comment out this line
setp hm2_5i25.0.xy2mod.write-timer-number 1
Then set all PID P values to 2000
Then set a reasonable acceleration value
(you cannot set it to an unachievable value,
this guarantees overshoot in the galvanometer)
MAX_ACCELERATION = 9999999999999999999 Will not work
Then when you are getting closer to tuning you need to add a little bit of FF2
(say around 0.0005 but this needs to be tuned)
You tune with halscope (plotting velocity and following error)
The following user(s) said Thank You: mahdi2001h
5 years 2 weeks ago #223362 by mahdi2001h
Thanks to PCW , your answer was very helpful .
My system is much more stable now.
Time to create page: 0.279 seconds
