- Thank you received: 35
On this note, it may be worth brining up halscope and watching the voltage at idle while not cutting. I found that I had my shield connected to table ground, and it was actually making the signal noisy, even at idle. I removed any connection to the shield, and the noise went away. I had asked PCW about it, and the basic answer was that whatever makes it less noisy is the best option.Try to catch what is going on with the voltage when that happens.
Seems like interference on the THCAD side, so first thing to change is the 5V going to it.
